caserupman
I have a 1956 case 310 utility. I have taken the cover off of the gear shift housing and cannot seem to get the shifter rods lined back up for it to go back on? It's the 12 inch by 12 inch metal cover over the transmission where you shift the gears. It won't go flush because something is binding underneath. Is there a correct procedure or trick to put it back on? Also how and where do I fix the seal that lets my hydrologic oil leak out. It's overflowing into the rear end gearbox fairly fast to where I have to add fluid daily as it leaks into the rear end and then out. ZAny help is appreciated!
