1936 CASE C REAR RIMS
OLDPARTSGUY
New User
DOES ANYONE HAVE A LINE ON SOME RIMS FOR A CASE C. THESE RIMS ARE RIVETED TO THE HUB WITH 6 RIVETS. THEY MEASURE ABOUT 20 5/32 INSIDE DIAMETER. IN NEED TWO IN ORDER TO HELP OUT OUR FFA GROUP AT SCHOOL
sorry cant help , other than to suggest that probably a dc or sc wheel will have the same size axle...many times one wheel vendor served 3 or more brands ,,. I would ask every brand on this tractor board ,, good luck
Are they cutoffs? If they are you can cut the spokes off the rim and weld new rims on. A picture would be helpful.
D and S series axles are different so complete wheels off one of those would not work.
I have a CC with rims like that. Cast centers with a steel rim riveted to the cast center. On mine someone cut the original rim off leaving a
small amount of rim by each rivet and found a rim that fit that circumference and welded it to the small amount of original rim by each
rivet. I guess JI Case Co. didn't think the rims would ever need replacing.
You should have given me a call, I have a set of rims like that on a CC that I would probably sell. Any idea what years Case used them? Rubber was available in 35.
(quoted from post at 18:20:59 04/07/16) You should have given me a call, I have a set of rims like that on a CC that I would probably sell. Any idea what years Case used them? Rubber was available in 35.
i still need these rims...have you got some pictures and a price.
I'm not sure on years because i cant get my hands on a c parts book
(quoted from post at 14:51:58 04/07/16) Are they cutoffs? If they are you can cut the spokes off the rim and weld new rims on. A picture would be helpful.
Are these the type of wheels your talking about ?
(quoted from post at 12:22:11 04/07/16) DOES ANYONE HAVE A LINE ON SOME RIMS FOR A CASE C. THESE RIMS ARE RIVETED TO THE HUB WITH 6 RIVETS. THEY MEASURE ABOUT 20 5/32 INSIDE DIAMETER. IN NEED TWO IN ORDER TO HELP OUT OUR FFA GROUP AT SCHOOL
