1070 hydraulics
36 A
What causes the hydraulics to not let the implement down on a 1070 . Is it something thats easy to fix or should it go to the shop ? Thanks
Likely the hose end is getting worn out. Try lowering very slowly, if that works change the hose ends.
(quoted from post at 09:00:07 04/07/16) What causes the hydraulics to not let the implement down on a 1070 . Is it something thats easy to fix or should it go to the shop ? Thanks
If you are referring to implements connected to your hydraulics, not to 3 point hitch.
-Incorrect connection of hoses, on mine top two couplers are one circuit bottom two are the second circuit.
-Seals toast in cylinder on implement.
-Faulty couplers.
-Mechanical binding.
If you are referring to the 3 point hitch, 99.44% chance that the control cable broke under the seat, right at the base of the yoke.
jon thats what he said if you drop it slow or feness it they go down . I could have put that in . Ok thanks
For me it has mostly been the male hose end causing the problems, but it can be either end.
