Adirondack case guy
I have been pondering the idea of installing a RH door in the factory cab on the 931.
Yesterday afternoon while sitting in my pondering chair, the lightbulb came on. I checked out the RH window and sureenough it was exactly like the top of the LH door. All I had to do was cut the bottom RH side window panal out of the cab and I had a door opening. It took me about 10mins to remove the panal with the 4.5" angle grinder. I'm now welding the lower panal to the window frame and fabing up some struts to mimick the ones welded into the LH door. This little project worked out to be quick and easy. Allready talked to Bro., and he is diging me put another Allen cab latch and handle assy from a combine cab for the 931.
The brake pedals may be a stumble point, but not much worse than the clutch pedal on the other side.
Tomarrow I will move on to building two sets of steps to get into the tractor. The factory steps on the LH side left a bit to be desired. I also fabed up a pair of light buckets which bolt to the lower front corners of the cab.
Loren
Loren
