cummins skid steer motor
01gentdc
found a cummins skid ster at auction ,,.what are the capabilities of this motor as far as what will they bolt up to ,,. I have a 470 rear end here ,,. does anyone know if that is possible ?/ thanx jim
I have a case 1845c with 4 cylinder Cummins in it, 1800 lbs. lift. does a great job for me I have 2 buckets and forks would be lost wit out it. been a good machine for me and do not have any real problems with it.
sorry need to clarify,,. the motor is out,,. and is being sold separate from the skidsteer
01gentdc, My boss has a 95XT,550G,580M,580E and 650K with cummins engines. The 580E engine looks identical to the cummins engine in my White American 60 farm tractor. If you need a bell housing engine mounts or clutch parts there is a guy that is putting together a kit to put cummins engines in Olivers. You may be able to adapt to your Case if you want his number i'll try to find it. Greg
AFAIK the Cummins 4-390 is just an ISB-5.9 missing two cylinders and any bellhousings and adapters that fit the ISB will fit the little Cummins.
I googled Case 470 tractor last night after thinking about the 1070 I helped work doesn't have a frame. A local farmer and his friends converted this Massey 65 to a 354 Perkins for low budget pulling! I would think the 3.9 would need a frame to support it just my thought. Greg
