One very easy fix and one not so much.
1370rod
A long time customer drop off their 1370 wanting me to repair a exhaust leak. Not being able to find the leak I decided to dyno the tractor thinking the problem would show up. It did not, but it sure made a wooshing sound that was easy to spot. After 40 years this pipe plug had loosened and fallen out of the intake manifold leaking out pressurized air. Simple to cure that problem. Then there was a leak on the brake valve of a 1070. Those of you that have removed and repaired these on a 70 series tractor with a cab know what a pain in the a$$ they can be. It looks simple but almost everyone will test their religion when doing this job. I have not removed many thankfully, one a these times when throwing stuff in anger I might actually hurt something, LOL. Rod.
Lol. Good times with the brake valve. So easy as a open station. It could be worst. 1170-75 has the big air cleaner & turbo & plumbing shoved under there. Cussing & special made tools required
When I was young I threw wrenches a few times but then realized eventually you had to go pick them up so I got over that. One time our shop cat at Case was trying to crap in some floor dry. I bounced a wrench across the floor, not to hurt he but to stop her from doing her business there. What a sight to see her wheels spinning in the floor dry to get out of there!
