wrenchhead1983
ok, i have been trying to figure out this tractor for some time now. to start from the beginning. i rebuilt all the power shifts. ran tractor and low transmission pressure light came on. preformed some checks per the repair manual. performed standby pressure check. was only getting 80 psi at idle and 150 at full throttle. put in a flow meter. fell on its face. had pump rebuilt. installed pump. ran. when cranking tractor over. would get the 350 psi. as soon as the tractor would start, pressure would drop to zero. drained all the oil and checked the inlet screen. had some fibers on it. cleaned all off. tried running again. same result, took pump back and had repair shop test. they said it was fine. they replaced the compensator valve just to try. no when cranking the needle bounces more while cranking but still drops to zero when starting. i tried plugging off the supply line for the gear pump. started tractor and had 350 psi while running. hooked up gear pump supply. started tractor and dropped to zero. took apart the brake valve mounted to left side of tractor. nothing found wrong. installed and started tractor with everything up normally. had my pressures for 15 seconds. took brake valve apart again. didnt see anything wrong. ran tractor again. didnt have my pressures again. i am not sure where to look next. any suggestions would help! Thanks ahead of time. Greg
