Mineral oil for power steering? Part kit G45077
So I installed the 5 rubber o-rings that came in this power steering valve kit, G45077. On package it says FOR MINERAL OIL USE ONLY. ATF is mineral oil based, right? My service manual says to use ATF so the dexron IV should be fine or do you use straight mineral oil?
Corey: Those P/S systems weren't too fussy. Dexron will be OK, my preference would be "Tractor Transmission-Hydraulic Fluid", such as "Hy-Tran. Good luck!!
(quoted from post at 08:01:34 03/12/16) Corey: Those P/S systems weren't too fussy. Dexron will be OK, my preference would be "Tractor Transmission-Hydraulic Fluid", such as "Hy-Tran. Good luck!!
Ok, sounds good. Thank you
