Adirondack case guy
God came up and spent the day helping me with the 931. We went as far as we could with the engine as we could. Heads and rods are in the machine shop. got the butt of the old girl buttoned up. laided the crank into the block and bolted the block back to the tranny with new clutch disc. Bolted the nose back on the block so it is setting on all fours again.
We dry fit the new sleeves and found that #4 & 5 are a bit low. John is trying to find me some .002 and .005" sleeve shims. #5 sleeve sets -.001 #4 sets at +.001. The rest are .+003-4" Pic of checking protrusion didn't upload first time around so it is now last.
We didn't have a clutch aligning tool, but Gods eye was real good. HeHe. Engine slid on real easy with the top of tranny still off. We could turn the tranny input and pto shaft to align them. That also made it real easy to adjust the clutch linkage as we knew exactly where the pedal released the disc.
I threw in a pic of the pto clutch adjusting tool also. People are always asking how to adjust these ptos and most think they have to drop the whole 3pt assy. to remove the pto. You don't.
Did some more bodywork on the cab earlier this week also. A tire chain broke and ripped up the lower RH corner of the cab and the fender. everything hammered out pretty nicely.
Loren
Loren
