connor9988
- Location
- Central Iowa
Grinding along on the MRB plow. I'm currently working on the depth wheel. After cleaning it off I see that at some point in its life it was broken and welded back together. My question is why are there so many combinations to its position for the front and back sides? I can see how you would either want the wheel "leaning" either to the front or the back of the plow but not really any other way. Also, why is there a circular hole cut into one side? Were there other types of depth wheels used with this bracket? My wheel is only clamped onto the bracket with friction and does not have holes to pin it.
Thank you.
Thank you.
