Fred in Utah
I need help rebuilding my 1966 DB 880 selectamatic clutch. I have purchased two new clutch disks and had the floating disk plate resurfaced on both sides. I need help getting the pressure plate resurfaced (how hard is it to take apart or should I just ship it to someone as is). The pressure plate has heat cracks in it so it needs to be resurfaced for sure. I would also like to know if i should remove the flywheel (won't break loose) and have it resurfaced (see picture)? I have had no luck here in Utah getting help on this project. The one case parts guy I went to didn't have a clue and I ended up wasting a couple of hours. I would also like to replace throughout (and other) bearings while I have the tractor split. The only numbers I can find is on the pressure plate..they are 52905 W2 15.
The tractor is in great shape for the year and will last my lifetime once I fix the brakes and rebuild the hydraulics (they lift great but drift down within a few minutes of shutting off).
Thanks in advance for your help.
