02/06/16 I have had the 52 Case since 1975. Have used it winter and summer. I have neglected to keep up with antifreeze and thermostat changes. The only thing I did is have the radiator soldered 15 years ago and add antifreeze here and there. My question is: when I drain the antifreeze and install the thermostat, put everything back together, do I put a gallon of antifreeze in and start the engine and wait for the thermostat to open and then fill with the rest of the antifreeze or do I put all the antifreeze in and wait til the level drops and the fill.
*************The funny thing about this tractor ever since I owned it is if you fill the radiator to the top it will always push out antifreeze until you have about 3 inches from the top.
Case52
Case52
