Adirondack case guy
I pulled the tranny cover on the 931 today. It looks really good for all the hrs on it, but it has one problem. The speedo drive cable twisted off at the very end where it's square end slips into the drive gear. As you know the speedo drive gear is on the front of the pinion shaft under the range gear shaft. How the heck do I get the tube that encases the flex shaft out to pull the broken off peice out of the drive gear. I can't fit my hand and a wrench down to take the bolt and retaining clip out to access it. I sure don't want to have to pull the clutch/bell housing off the tranny to get to it.
Loren
Loren
