111
Just picked up this 1370, runs good but has trans problems, The guy I bought it from was driving down the road in high gear when something locked up and the tractor went almost sideways, powershift slips in first and reverse other power shifts hold fine, this tractor is pretty rough anyway so I think she will be a good tractor to transplant the 504 into my 930. Here is the 930 I want to put it in. The 401 in the 930 burns oil and has 2 bad valves
Ben
Sounds like a fun project. Keep us posted as the transplant takes place. I have never done one but we know there are fellows out there that have and can offer some good advice. Rod.
Thanks Rod,
I will keep you guys posted, what do you suppose happened in the rear end that would cause it to lock up like that? I guess there were no symptoms before this happened.
Thanks
Ben
Tractor must have a couple issues, something had to let go if a side locked up going down the road. Never had that occur. And if power shift slips also I would do what you are thinking of. Use the engine and part out the rest. Rod.
Where abouts are you ? I would be interested in the front wheels. Thanks Greg
I could give you what i have , i like the wider rim
Do you have any videos of that 930? My 930 is just getting that engine but won't be pulled, I want to buy another eagle hitch 7 or 830 or maybe another 930 and buy 2670 that I know about that has a bad powershift and use that engine and bump it up to about 300hp and pull with that.
Ben
I am in Ontario, just south of Windsor, I'm not sure what I'm doing with the rest of that tractor yet, I have 2 1570's and another 1370 that I use, I always need tires, the rears are Goodyear radials so I am keeping them, they are worth more than I paid for the whole tractor. I will keep you guys posted on the rest of the tractor
Ben
