New Member of the Herd
1370rod
Bought as a parts tractor, C-1 is locked up and it is not the pilot spool. Will repair if it is not to many dollars, nice running tractor otherwise. Rod.
looks like 1200 or 1470 wheels,,, I have not seen them either,,,, interesting,,, click on the link, it does show a bolt on rim but only lists it for a bigger tire,,, maybe some one changed it to a narrower rim??? I also never knew they had power adjust rims for them!! glad you got it Rod, I have little doubt you will fix it
cnt
parts link
Not a bad looking tractor Rod, I do know I sent a lot of 24,s and 26,s to the bone yard for problems like this, as it seemed once they got started in the shop on them there was like a large thermometer on the wall! Like a fund raiser
Rod, I guess you can control most of that doing your own work. Good luck on her Rod, keep us posted
Tom the tractor was used in ridge tilling and the owner never used duals. I am sure the he must have had them made to exactly fit his row width and would be stronger than using the individual lugs. Rod.
Sort of like some women. Real looker on the outside, and ugleyer than sin on the inside.
Looks like a project that is rite down your alley. Has the 14 seen this one, and has it still got a smile on it's face?????
Loren
Loren the 14 has not met this 24 yet, it has nothing to worry about, it will not lose its job. If I happen to fix this and decide to keep it around for a while the job I want to try it for is on the snowblower. Dang I think it should be awesome for that job. Geez what do you suppose the 870 gasser will think of that? Rod.
Geeeze Rod, Install a couple of cameras for a Cab Cam system on the back and hire out to the local hwy dept. That is a lot of tractor for a snowblower.
Loren
Loren, Actually our township does look for someone to remove snow in the worst areas after bad storms. Could be fun, 2470 to the rescue. Rod.
Rod,
Nice looking 2470. Certainly would be interesting to see it on a snow blower. Wheels certainly are different.
Eli
Eli the wheels were custom made to fit spacing for ridge till. They are like the 90 series duals for the 4wd minus the deep dish. I to hope I can repair it at a
reasonable cost so we do have a chance to see how well it works on the snowblower. Rod.
