rened zuniga
Case Nutty 1660; I posted earlier that my 580b hydraulics had gone out and you responded that the pump spindles were probably damaged. YOU WERE RIGHT!!
The pump shaft looks like a new bolt, no teeth (spindles). The coupler from the engine looks almost worn out too, with spindles half gone. Therefore, some important questions before I proceed:
1. How difficult is it to get to the coupler's four bolts on the engine?? After taking the pump off, I noticed there are heavy frame parts that may need to come off to get to the bolts, and even more, to get the part out of such a tight space. WHICH IS THE BEST WAY TO TAKE OUT THE COUPLER BOLTS AND ALL???
2. Regarding the pump shaft, I see there are 6 bolts around the shaft area. Any thing I should be looking for while taking it apart to replace the shaft??
3. Advice on possible alternative - it seems that on the engine coupler there are still good spindles on the back part of the coupler. If I am able to find a longer new shaft and cut it long enough for it to go dip into the old coupler, would this work?? (Probably the cheap and lazy way of looking at it, but just wondering).
Finally, just for you to know that your earlier response was quick, clear, professional, and right on the nail. I was able find the problem with ease. Awesome!! Thanks again. David
