Hey all, new to the forums seems like some great info so here goes...
Neighbor bought a old 1070 powershift for too much and wants to fix it up. seems everything is working except the three point won't hold a load up without having the engine sped up some. also quite slow to lift. The sensing lever in the cab does not move, and to me it seems like the 3 point lever doesn't move back as far as it should. Power shift works well in all ranges and pressures in the green in all ranges.
I changed the filters first off and it was missing the relief valve in the back filter. I got a used one from a local yard but I have no idea how long it was run without the valve in the filter.
We put on a different pump, and also replaced the o rings on the three point cylinder with no change. Which was not very fun by the way. trying to avoid having to pull the cab off again any help would be wonderful.
Thanks in advance!
Thanks in advance!
