Fred in Utah
Had a great day yesterday splitting my 1966 David Brown 880 tractor for a two stage clutch R&R. Everything went great all the bolt and nuts cooperated and came loose without any major problems. The question I have is how do you remove the flywheel? I removed the four bolts holding it to the crankshaft but could not get it to break loose. I took out the starter and tried knocking it loose from that side but it didn’t budge. Am I missing something?
I would like to resurface the flywheel but if I can’t remove it should I just replace the clutches and resurface the floating flywheel? The floating flywheel had heat cracks on the outside. The inside clutch was oil soaked and sticking (that explains why I couldn’t engage/disengage the PTO without grinding gears) but the flywheel didn’t appear to have any shinny smooth spots on either the floating or regular flywheel. Thanks for you advise and help.
