I want to put new rear tires on the SC. I use it only for tractor rides so I would like to use the center rib Titan WHO
FFA tire. Do you guys have any pictures of 12.4 or 13.6 tires on a SC. I am interested in what each size would look
like on the tractor. I do realize it also means a rim change.
If you have 12.4s on it ,13.6x38 will work on your 10 in. rims if that is what you have now and give you a little more ground speed. Just a thought.
Here is mine with 12.4-38 tires. My tractor came with oversize front and rear tires when it left Racine. Thus, it came with 10" wide rear rims and 11-38 rear tires. 12.4-38 is the modern equivalent of 11-38.
Pastor a buddy of mine was able to get a hold of used 14/9/38 and he put them on his IH Super H 1954 used the factory rims yes they are a little rounded but still look good and helped like heck for tractor puts I am sure they would be to much horse power loss for field work but I am sure you would like the extra speed good luck and happy new year.
Thanks for the input guys. If someone has a pic of a set of 13.6 on a SC pass it on to me. Not sure if raising that rear end will make it look odd? Thanks again
Pastor John, Here is my SC with 12-38 on 10" rims. Can't tell in this photo, but the tractor does sit a bit nose down when on level ground.
Pastor John--I don't think you would need to change rims, however, if you decide to, I get mine at CFI in Des Moines. They make, repair and sell all kinds of rims. Good luck and like your SC. I have a restored Model S.
