I am slowly picking at my VAC-14. I hope my brakes are in working order.
While I have the rear end drained (switched out axle seals) I have an oil leak on top where the torque tube meets the transmission I need to address. I have run the tractor so little, I am unsure, but I think it's transmission oil as opposed to hydraulic oil. What would be causing this? I am sure nothing is overfilled.
If I knew what was causing the problem it would help, but I am considering just separating the housings a little and sealing with permatex.
Any ideas what's causing the leak? All systems seem to be operating correctly.
Thank you,
Glenn F.
Thank you,
Glenn F.
