Update on 52 case SC repair
Bhunt
I'm posting photos of where I am on the tractor Thanks to all who have helped!
You will have a sweet runner when you get it back together. Are you re-using the sleeves or replacing them? I ran into eroded sleeves like that in an F20 and after hemming and hawing for awhile about whether to re-use them I searched around and found a good used set of S&P's. My favorite little SC is getting tired so someday it will come apart too.
(quoted from post at 22:11:28 12/13/15) You will have a sweet runner when you get it back together. Are you re-using the sleeves or replacing them? I ran into eroded sleeves like that in an F20 and after hemming and hawing for awhile about whether to re-use them I searched around and found a good used set of S&P's. My favorite little SC is getting tired so someday it will come apart too.
Right now it looks like I will reuse the sleeves the new rings are all within limits in the used sleeves.The severe corrosion on the #4 is below the compression line. Now like you said if I found a good replacement for the one bad #4 sleeve I would likely buy it. Thanks I'm looking forward to getting it back together. I really hope it all works out for you as well Byron
