need to fix Brakes
01gentdc
I shouldfix brakes this winter on a 730 , 430 and 530 ,.. the 730 is simply poor braking ,..probably can clean the parts and all will be better???? the 430 and 530 have the pesty lockin up problem that is not a problem til cold damp weather ,..I am thinking the ball bearings are causing this ,, and I also think there mite be a shim adjustment that can close the problem ?,,. anyone got any advice ??
I would start by sizing up what is wore out . i.e. seals ,brake pads, springs? You will have to drop the tranny fluid level first, but a small price for doing it right. Since some models do not have certain style seals available . like mine, I will double up on the modern seal. Orientation of the first seal is as important as the second seal. Good luck Chuck
