Loren Adirondac Case guy a question
JOCCO
Hi I understand you do maple syrup, question for you. What will cause lumps/hardened crystals in the bottled syrup? These are large taking up 20% of the bottle. It was supposed to be filtered (not through a press) any ideas, over heated, not filtered enough?? thanks
The sugar is crystilizing in the bottom of the container. It has nothing to do with filtering. If you can get it out, just heat it up in the mycrowave and it will turn back to liquid. Syrup that is boiled down a bit too much is more prone to crystilizing if not used in a reasonable time period.
If the stuff in the bottom is gritty like really fine sand or buffung compound, it wasn't filtered to take the sugarsand out. Sugarsand is calcium that is suspended in the sap as it flows up the tree. When boiled down to syrup, the calcium turns back to a solid, and has to be filtered before canning
Loren
