casered
I am restoring a 52 model DC and I am in need of a decent set of fenders that are not all rotted out or beat up. Does anyone know of a good source for them? I just am not seeming to have ANY luck in locating a pair for it. Thanks for any help.
If you have a set of fenders in need of repair....I make a repair panel for them. DC SC 400 700 800 730 830 fenders all take the same repair panel, made of 16 gauge steel (original was only 18 gauge) 605.881.2433.
Yes I have the originals and the portion that is above the mounting bracket is in decent shape but where it goes over the bracket they are rotted away. Does this panel cover just the bottom portion where they mounted? Do you have a picture of your panel you can post? I am in PA when is a good time to call you? Thanks.
The repair panels are 2" taller than where they rust off. You have to clean the back plate up and weld the new panel on. Directions come with the repair. See if I can load the pics.....
HAHAHA!!!!!!! Yeah she seemed to be "not happy" when I called. I looked at the fenders this afternoon and I think they might work. I want to get them home and look at them closer though. I will be back in touch.
Thanks again.
