New Case plow
tak8098
Bought my first case plow, a neighbor had it in an old machine shed. Seems to be in pretty good shape. Beings I'm new to plows could someone share some info on this plow, model, year, etc. Thanks.
As Roger said. Plus it's either an AH34 or 36 and earlier one since it still has green/orange paint. A Series, H- hydraulic lift, 3 btm, either 4 for 14" or 6 for 16"
Brad
I've never seen one like it. It has the old style rail type beams, but yet the modern square tube on top. Also has the later "Raydex" Bottoms.
all series "A" plows had the rail road iron frame, every one we sold was like that four bottom was the smallest we sold almost all were 6 bottoms I have this one that was sold new with a 1966 1030
That is a very early Green Axle, A Series Plow I'm fairly certain. Can't see the lift for sure. You will love how it pulls and plows regardless. Three bottoms are pretty hard to come by, it is a great find. Bob
Really good plow find.You will probablyy have to lower the a frame hitch at the plow
for it to pull properly .Depends on tractor hitch height .
tak8098; that is the first series of the a-series plows, and I believe they were only made that way 1 year. it has the curved I-beams that go all of the way down behind the moulboard. I also have a 3 bottom the same way, and 7 a-series plows that are not made that way. I believe the 1'st series came out in 1957. hope this imfo helps. john
I pulled an early one like that at a plow day two weeks ago. Sure plowed nice. It belonged to a friend. I have a 4 and a 5 bottom A series. Would like to have a 6.
