oil change in a 580 ck how often
i am cleaning out my shuttle section with diesel like stated on here some of you guys say to do
then i will try it again i will let you all know how it goes tried to run it after motor swap found
it not pulling so drained oil out took all components off top and found the screens was stopped up
with what i call slugge just wondering i have a service manual owners manual and a parts manual
ordered a new power steering pump and a new water pump next probally new seals in the power
steering cylinders so everything is like it should be any help on a good place for seals other than
motion industries they all ways have to order in when i go to get parts
CASE construction dealer can get the seal kit for the cylinders, have them do a stock order, they get free freight on them, as for shuttle oil change, once a year or 1000 hrs
thanks case nutty 1660 always coming thru for me and the other guys on here also i am hoping to get this thing up and running good the bad is i really wanted a back hoe with it so as i am going thru craigslist i run across a 580 ck 1969 year model needs a motor rebuild oh well just my luck after i get this one up and running i may try and buy one then but like as usual they will not have one no wheres to be found lol
