John Saeli
CASE has long ago obsoleted F30126 Tranny Drive Variable Speed Drive Belt for the REAL CASE 1665 Combine. Different from the 1660, and no print available. What are you guys doing for that Belt that are still running that Great Combine?
I have a Goodyear made variable belt on the 1665. I can get the number in the morning if you need it. Got it from the local bearing house. Did you try JayDee belts.....they have had traction drive and separator drive belts...haven't tried them on variable belts.
I went to the JayDee website, F30126 isn't listed....but they do sell variable belts by the width and length, or maybe that part number has been changed to another. May need to get someone on the phone to answer questions.
Number never changed. I have 1-13/16" X 124" written in my Book. Hope I can trust that is correct. Yes, I would appreciate a number. Thanks.
Goodyear HL 1270....measures 127" outside, the variable drive shaft is slid all the way back so it must be a little long....works good though. The other 1665 has a factory Case belt measuring 125" so your numbers are correct. Powertorq is another company I have used also. Maybe Goodyear has a HL 125....got mine at Cartney Bearing Watertown, SD.
