new case addition
s,mac
Here are pictures of the latest Case addition. The 36 CO will become steel wheeled with full orchard sheet metal. The rear tires are going on a 51 Oliver 77 orchard. The 51 VAC I will get it running then make a decision. I have been looking for a wide adjustable front axle for some time. These tractors came from the same estate sale as Dick Benson's. The Case plow was a nice extra. Steve
I have never seen a 51 VAC with the steering rod and steering gear box like that. My 51 has the steering shaft going into a gear box under the radiator.
Richard in NW SC
The sheet metal and steering changed with tractor # 5570000 which would have been late in the 51 year model. With the later sheet metal being wider and taller it also allowed for a slightly larger fuel tank (approximately 1 gal). The dash lay-out was different as was the hand throttle. Tool box door had to be moved to the right since the steering shaft came down through the dash. Lee
Steve - Nice tractors you got there. If you decide to get rid of that plow bring it to steam-up next year and we can talk. I would love to see that hooked up to my '51 VAC-13 SER#5570036 -Noel
