FarmerBrawn
New User
1030 has been acting up. A couple times while discing it would stop raising disc. It happened a couple times and I always got it to raise eventually. Seemed like it lifted slow a couple times. Yesterday I started it up cold and the disc only raised a couple inches off ground.
Three point works fine. I put it under trailer hitch and lifted the back of the pickup off ground. Not sure what pressure that would require.
Aux controls are a rebuilt unit that has not been used much. The relief valve is on the bottom. Doesn't look like the IT manual. It is unshimmed and the oring looks ok. It is kind of hard so I will replace. The piston goes in and out of sleeve easy.
The plastic valves with the balls in the side caps look fine.
If the draft valve is bypassing, will it affect the aux controls or do they have priority? Anything else I should do before talking the draft valve off? I hate messing with that thing.
Thanks
Thanks
