How hard is it to find a narrow front for 1030 case?
D17puller
Hello guys how scarce are the narrow
fronts for a 1030 case tractor? I am
looking for one. I have a narrow front
for a case but it appears to be way to
small. It measures 15.5 inches tall and
21.5 inches wide from side of spindle to
side of spindle. What could this be for?
Thank you!
1030 never came from the factory with norrow fronts but the norrow front from the olg round nose 400 and up will fit. The operators manual on the 930 says that when you put on the norrow front that there is a ring that bolt to the steering housing to straighten it. Also keep in mind that if your 1030 is a western if you change to a norrow front it will steer backwards.
