dick benson
My recently purchased 51 VAC was missing a hydraulic tube. Someone replaced it with a hose. I found the lines on e-bay(actually two lines with a coupling to connect them together. My problem is I need a connector fitting where the line connects to the front hydraulic pump and I need the elbow on the other end where the line connects to the right front of the rockshaft. Both ends are female flare and the pump looks to be 1/2" pipe. I assume the elbow going into the rockshaft is pipe also. On attached photo it is line VT-4918 and VT-2993.
Any Ideas where to find these fittings would be appreciated. Dick, OR.
