4490 steering
VAC400
Working ground with the 4490 and it is in all wheel steering. All at once the rear wheels will turn, has this happen to anyone else? Jerry from Ohio
Have a 4690 I bought last spring....if you put the selector in coordinated steering it goes hard left on the rear wheels. Also , front steering is hard to turn, having only 1200psi at the steering cylinders.....took a shim from the relief valve, but didn't help. Love the tractor but the mickey mouse steering set-up is ridiculous. Have had a 2470 for 25 years and never a problem. No mechanics around that know squat about the system. Have to find a repair manual and figure it out myself I guess.
John Anderson @ Titan Mach'y has a printout of a checklist on where to start. His phone: 800-648-4004. It's an ingenious system, but 35 years of moisture & dirt take it's toll.
Could you give a little more detail on the situation. Are you running straight when it does this. Are you making a small correction. More details would help. Tom
