Any help with this would be appreciated, Have a 1394 that was obtained in summer, had clutch issues, the rest of the tractor is nice, and it has cab, so it's worth a little time and money to fix, But clutch will not release to put it in gear, I had it working a little while but it went back to not working, the master cylinder is working fine, and also the pto clutch has never worked, and the lever on the outside will not move unless you hit it with hammer, it acts like it's froze up, I have IT manual and was thinking about splitting tractor to rebuild clutch, unless there is another solution. It looks like quite a job to split this thing too.
