Hello, I have posted a couple of questions concerning my tractor a month or two ago. I have issue with my tractor hydraulics. It seems to be isolated to the remotes. The 3 pt seems to be working fine and steering and brakes seem to be okay. My gauge for my hydraulics is barely in the green above the yellow side but in the green none the less. When you try to retract a remote cylinder it won't retract. It seems like it might try just for a second but, no movement. I feel like it would extend if the cylinder would retract. I had an issue a month or two ago with one of my levers engaging itself causing an issue with it overheating. I found that problem and fixed it recently a little ball for valve had fell out during a hose replacement I am assuming. Does it sound like I need to replace the valve assembly. I would hate do all of that and then find out it is the pump too. Sorry for this being so long but, any help for my issue would be greatly appreciated.
