robilmichael
Hi, I have a 480ck with the 188ci diesel engine. It will not start and no fuel is getting to the injectors. I double checked that the fuel shut off was open and the cable for the fuel shut off to the pump was in the correct position (i.e., not shut off). I thought that it might have run low on fuel so I put more fuel in and it is filled. I bled any air out of the filters by opening the bleed valve and fuel flows freely from the filter. I opened up the line to the pump and fuel is getting to the pump. Fuel is not getting out of the pump. I opened up the lines to the injectors and still no fuel to the injectors. I cranked the engine for quite a bit of time.
It ran fine last week when we parked it in the barn. The manual and service manual does not point to any bleed valve on the pump. However, there is a bleed bolt on the side and I opened that and still no fuel, but it did drip about one drip per 3 seconds or so.
Any suggestions? I cannot believe that the pump just quit as it always ran great and always started up.
Thanks for your time, and expertise.
