Case 1070 manual
I am looking for a case 1070 operator manual. I have found several but they say they are for SN 8770001 and up. The serial number on my tractor is lower than 8770001. Is there a big difference in the books. Thanks for help.
No big diff at all,, they did change the fuel primer pump location, and the color,,, and a few items like high idle rpms and some steering parts, as far as a ops any will work fine, you can also still order the correct one from CNH
cnt
(quoted from post at 07:57:57 10/05/15) No big diff at all,, they did change the fuel primer pump location, and the color,,, and a few items like high idle rpms and some steering parts, as far as a ops any will work fine, you can also still order the correct one from CNH
Thank you for the info. What is CNH and how do I order from them. I would like to have the original.
cnt
CNH is CASE NEW HOLLAND,, they also go by CASE IH call any ag dealer, have your serial # ready, they can order you one, takes a wekk or ten days from my dealer most times,, hope this helps
cnt
Here's the correct one on e-bay right now. The original is of much higher quality. The manuals Case sells over the
counter for these older units are reprinted, but not with high tech printing, barely copy machine quality and I would say the
photographs are unusable. The verbiage is ok and the line drawings usable. I got sucked into a couple hundred dollar
reprint of the 1070 shop manual. The section on the power shift is unusable, arrows pointing to assemblies that are a blur.
1070 Operator manual
