DB80 Spraying PS Fluid
jtwat
My newly acquired David Brown 880 Simplimatic is squirting fluid from the power steering vent hole on the cap of the res.
I changed the filter and noticed the fluid was foaming. None of the hoses are leaking.
Used ATF in it. Wrong fluid?
For some reason, the pump is sucking a small amount of air which results in foam and the reservoir becoming overfull of the oil air mixture.
See this thread and do all that is recommended.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=case&th=276177
(quoted from post at 06:54:38 10/01/15) See this thread and do all that is recommended.
Some of that doesn't apply. Pumps for the 3 cylinder tractors are a different animals than the 4 cylinder ones.
