deckplate bore 504
I am looking for the tool to true up the deck bore on a
504 {2670} engine. I do not know if this is a Case tool.
We had several 30 series blocks trued up years ago but never a 70 s block.
We are cracking sleeves.
I do have the CASE tool used to true up the counter bore that the sleeve flange rests on. I do rent it out with a sizeable deposit and it is heavy making freight a little costly. I also have shims in stock. If you are interested let me know, Rod.
Any good engine shop should have a tool to do that. At the engine shop I worked at we did anyways. It's not brand/engine specific, just a universal counterbore tool. If your shop will do work on the road, it can be done in frame quite easily.
