4490 steering problem need help
1968 403
While disking ground yesterday going straight down the field the rear wheels suddenly on their own turned hard to the right. The rear wheels will not straighten in 4 wheel steer or front wheel steer. Any ideas what the problem is? TIA Keith
First thing I would do would be to clean the filter for the rear steering if you haven't already done so.
Can you straighten the wheels using the left/right switch in the cab?
Have you checked the steering sensors to make certain you don't have a loose one or a loose set screw. If those are ok you have some more diagnostics to do. John had to replace a cable. Would be great if you had a service manual. Tom
