1175 rear wheel question
ljm
I would like to remove the cast weight between the planetary and the rim on my 1175. I'm sure those planetaries were used on other applications. Does anyone know what else used the same planetary? I would like to put stamped steel rims on. I would either stay with 20.8x38 or go to a 23.1x30. Case offered the stamped steel rims, but most 1175's have the cast weight.
Does anyone have suggestions as to where I might find rims that will bolt to the planetary?
Thanks
I had the Case dual wheels on mine that were widened to 20". Had an extra set, but sold them with the tractor. Not easy to find, but they are out there. Some say Oliver 2255 and others like it have the same bolt pattern, but I'm not sure of that.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto28177.jpg"/>
