Tom Dold
I a unable to find a sleeve and piston kit for 210B Case with a 126 Engine.
I was wondering if the 146 engine has the same sleeve parent bore as the 126 engine.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349
605-772-4541
[email protected]
I could put together a kit, but $$$. The 148 Sleeve has a slightly larger O.D at the O Ring area of the sleeve, not much. Or, in other words, the 126 Lower Sleeve Bore is slightly smaller than the 148. If you could chuck the 148 Sleeve in a lathe, I don't think you need to remove more than .010" in that area of the sleeve. I could be wrong on that number, but it is not much. The upper sleeve flange is the same.
