Well i've got my first tractor home now and have gone over it and once it gets a good degreasing, tune up and maintenance will start. I hope someone can answer a few questions for me until i get a manual though.
1. It has what i think is a factory case loader. Its working, but i was still able to put 5gals of fluid into the right tower, and there's room for more. It appears to be plumbed into the reservoir under the gas tank as well. There is a pump on the front of the engine driven by the crank. Is this the only hydraulic pump or is there another for the 3pt?
2. Can i determine year based off engine SN? Its a gas sn 2659202. The tag on the dash is missing. It has two cylinders for power steering.
3. The "transfer case" has three positions, ? N ?, would this be direct drive & low? If so, what position is which?
4. It has a model 31 backhoe attached which I will be removing until spring, as I need to use a snowblower. It looks as if the subframe for it is welded to the tractor in spots. I will need to attach 3ph liftarms and draw bars, would anyone happen to have a pic of that setup? I'm not sure I have all the needed mounting points on the back axle tubes
Engine oil and trans oil is both like a vanilla milkshake, it'll be flushed. PTO brake & clutch to be adjusted, also no brakes.
I'm leaving town for a month and would like to do as much parts sourcing/info gathering as possible while I'm away
Thanks for the help!
