adding oil to transmission on 880 DB ?
PTO seat was leaking. Pulled the seal and had to order one, no one stocked it. I drained the ugly/milky oil on the 880 transmission using the plug at the filter screen and also pulled plug under swinging drawbar. I notice there is two fill plugs? One on top of tranny case and one behind the left side of the seat on top of the PTO housing. I filled the front housing (tranny Case ) do I need to ad oil to the fill plug behind the seat? Dick, OR.
Dick, just the fill plug on the trans cover. Will look for sure in the morning. I have a few of these critters.
That PTO seal is available through NAPA. I just got one. I can give you the seal number is you need it. It was still $19.00 though.
