A young friend has a Case 311B and a 530CK (gasser). He has owned them about 3-4 years and in each instance we put in new ignition parts when he got them. Last fall the 311B acted up and upon examination found the points had worn away to the point the movable arm metal stamping was the only thing making contact. The fixed side wasn't too worn. Yesterday his 530CK failed, same issue. The contact on the movable arm was almost completely gone the fixed contact not so bad. I got worried about my VAC which has a similar distributor (if not identical uses same points) and looked at it. The contact on the movable arm is just about gone. These are older but she is only used in the summer with a finish mower. Points were i believe either TISCO, Standard Ignition and maybe one was NAPA. Is it normal for them to be eaten up so fast??? The rotor cap and spark plugs are still good on all three tractors...
