730CK-COM Trans MPH
JCCWI
Thinking of going to local antique / classic tractor pull Sat. Anyone know wt. of 730 CK and mph in 1st and 2nd gear - direct? Can I pull in torque converter side????
Thanks......John
Weight, according to owner's manual is 7000#
Use to pull a 800 gas tractor. Pulled in 6500 and add 1000# to pull in 7500# class. Pulled in 2nd direct or 3rd case-o-matic. Build a clevis to bolt to drawbar quadrant and space it up to 20" pull height. Move original drawbar left or right to be out of the way.
Thanks for the info on the 730CK.....as it turned out , I had too spend too much time getting some late 2nd grass out
of the field and ran out of time.
Did take the 52SM off the rake and when to the pull.......I have pulled it a lot over the years but not much the last 4 years. Took third in class of 8.
New 45 degree PKT tires did not grab the track as well as wellworn GY traction torque,s
Will scale 730 tomorrow when I scale last box of oats. Will give me a starting point at least.....Thanks again!
John
