After cleaning all ignition/electrical contacts it seems I now have consistent spark. Tractor starts every time now (fingers crossed). I truly don't know what corrected the problem.
Now, it seems the only way it will idle down is with the idle screw turned ALL the way in. And at that it idles rough. Do you suppose there is a clogged passage somewhere after sitting eight years? This carburetor is not real easy to remove.
Thanks,
Glenn F.
Thanks,
Glenn F.
