Case BER Plow Sway Lockout (Pullbar Lock)
connor9988
Location
Central Iowa
Ive seen several pictures posted on here of BE series plows with the Sway lockout (Pullbar Lock) on their BE plows that limits its ability to sway on turns (plows even and straight). I was wondering if they could post a picture so I could see what they look like up close and how they work. I've found a picture of it in a manual but its not very clear.
Thanks
I don't have a good picture, but it is a piece of ~3/8" bar stock bent into a c-shape with a hole tapped for a ~3/8 square-head set screw on the top. There is also a piece of ~1/2" square bar welded to the bottom on an angle to make reattaching the mast easier (when it pulls out). These stops are not meant to prevent a reduced plow from swinging to the side, the manual recommends that you use them to keep the plow from banging back and forth during transport.
Here is a sketch of the left-hand stop. The right hand stop is a mirror image of this one.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto26756.jpg"/>
