Case Front Rims on 730
Lee Brown
I have a Case 730 with what I think is a Schwartz front end. It has a rim with 4 bolts around the outside and the center hub on the wheel. The "wings" on the rim broke off when I had too much weight on the loader. What are those types of rims called and where can I find one?
Thanks for any assistance you can provide.
they can be welded bak , , of coursed remove the tire fron the whneel ,, sonds like you have the standard cuss wheel that case put on 800 s , 500s, 630s,and more , there are at leastt 3 different ways to bolt on the wheels for wide or narrow settings ,, even for narrow front ,.. now the trouble if you only have one tractor with wheels like that and no spare , you are done when you blow a tire on a widefromnt,.. that's one reason I call them a cuss wheel , server;l more,, changing one in the mud , chit, or other slop getin a wrench inside to hold the bolt isa pain, keeping the bolts tite is a pain ,, when they start working loose occassionaly replace them with fine thread grade 8 bolts,, continued use with slippagewill break out the wings ,, my 730 built in 1961 has pressed steel wheels with a 6 hole implement pattern ,, hooray,, "now I can interchange wheels in a pinch" I was thinking when I seen then when it wandered up the driveway the 1st time lookin for a home,, was nt long I found out??? WRONG !!! ,, the center hub is too big to allow a standard 6lug implement wheel to go over ...
