Case 770 Agri King Fuel Tank
you guys have been great at helping with my tractor problems. Have developed a fuel tank leak. 1st how do I remove the tank and 2nd leaking from the left side any ideas where the problem might be? Any help is greatly appreciated. Thanks Bob
The tanks are held in by straps over the tank. The front end of the strap has threads on it that stick down through ahead of the tank. The nut on it can be seen under the platform from the back. If you have a cab tractor there is a small plate just above the tank below the rear window to remove so you can lift the tank a little to slide it out the back end. Leak should be easy to find once the tank is out.
