2294 Hydraulics
karl h
Can someone please explain the difference between having the remote valve lever pulled and locked into the rearward position and locked into the full forward "float" position.
Locked in the rear position it maintains pressure. Could be used for down pressure on a no till drill, or flow for a hydraulic motor. Locked in float there is no pressure other than the stand by pressure, no flow.
so if I am running my baler with the tractor in float mode and the baler opens it's valve to get more oil will the tractor "sense" that request and supply oil to the baler?
